Activity › Forums › Apple Final Cut Pro Legacy › NTSC Music video to PAL Conversion
  • NTSC Music video to PAL Conversion
    Posted by Mark Bennett on September 18, 2012 at 9:44 am
    Hi Guys,
    Final Cut Pro 7
    Hi guys I have a music video that was shot NTSC that I need to convert to PAL without speeding up the actual song.
    Would anyone know of a simple workflow that I can do in compressor to convert this?
    The original sequence settings are 1920 x 1080, apple prores 422, 29.97fps.
    Thanks again in advance
    Rafael Amador replied 14 years ago 2 Members · 3 Replies
  • Rafael Amador
    September 18, 2012 at 12:51 pm
    Standard conversion wouldn’t affect the audio, just the video.
    There are standard conversion folder in compressor.
    rafael
    http://www.nagavideo.com
  • Mark Bennett
    September 18, 2012 at 1:00 pm
    I know but when its converted to PAL it speeds up the video by something like 4% which means I cannot sync the original audio with the new converted video. If you get what I mean.
  • Rafael Amador
    September 18, 2012 at 4:07 pm
    [Mark Bennett] “I know but when its converted to PAL it speeds up the video by something like 4% which means I cannot sync the original audio with the new converted video. If you get what I mean.”
    This happens when you “conform”.
    Then everything will be speed up and the length of the program will change and so the pitch of the audio.
    And 4% speed change would be when you conform 24fps to PAL.
    Conforming NTSC to PAL, the stuff would be slowed down a 20%.
    Standard conversion keeps the same program length. Some frames from the (1 in 6) of video are dropped and the audio remains as the original.
    rafael
