ntsc monitor and client monitor
Hello – newbie here, currently setting up a person edit suite. Recently just bought a JVC DT-V9L1DU, 10 incher – along with the Blackmagic SDI card. Trying to setup as professional of a suite as I can, in the most economical way.
I want to know if there was anyway to duplicate the image on that NTSC monitor to another screen, to use for a client monitor? The NTSC monitor is a bit small, and I wanted something larger for viewing. Is this possible?
If not, what is a possible solution to this?
Any help appreciated –
B.C.
