Activity › Forums › Adobe Encore DVD › NTSC ISO Corrupt but DVD okay.
  • NTSC ISO Corrupt but DVD okay.
    Posted by Tim Bond on February 23, 2007 at 10:34 pm
    Hi all,
    I built two versions of a DVD: one in PAL the other NTSC (converted PAL avi’s with ProCoder) built them both as ISO’s to go to a replication house and they could burn the PAL version with no trouble but got an ‘unknown file format’ error with the NTSC version. I tried my ISO with Nero image drive and got the same error but when i burnt straight to DVD out of Encore it worked perfectly fine on the PC and the set top. Any thoughts as to why?
    Tim
    Tim Bond replied 19 years, 6 months ago 4 Members · 4 Replies
  • Ashley M. kirchner
    February 25, 2007 at 6:55 pm
    It’s entirely possible that you got a bad burn on the ISO. I would try to recreate it again.
  • Neil Wilkes
    February 26, 2007 at 2:58 pm
    It’s also quite possible all your menu sizes are screwed.
    PAL = 720×576 and NTSC = 720×480.
    They also use a different Pixel Aspect Ratio:
    NTSC = 0.9, PAL = 1.0166.
    Additionally, I would not trust Nero as far as I could throw the installer disc.
    It’s only any use for burning DVD from images, and should never be used to create the disc from a folder. It’s asking for trouble!
  • Jeff Bellune
    February 26, 2007 at 3:22 pm
    And Neil usually takes care of this, but since he didn’t, I will. 🙂
    To burn an image quickly and properly, use the freeware program ImgBurn.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Tim Bond
    March 2, 2007 at 8:20 pm
    Hi all,
    thanks for the thoughts – only just had a chance to log on again. I burnt the ISO’s straight out of Encore – just used Nero to try and read them. I did the NTSC build from scratch as an NTSC project so all aspect ratios / pixel size etc should be okay. I sent the rep house the straight DVD and that seems fine. Just an odd occurence and hopefully a one off.
    Thanks again,
    Tim B
