Activity › Forums › Adobe Premiere Pro › ntsc and pal
ntsc and pal
Posted by Kerry Grayson on September 27, 2011 at 11:36 amcan i work with ntsc and pal footage in the same sequence? and export it as a pal movie
Vince Becquiot replied 14 years, 11 months ago 3 Members · 2 Replies -
Ben G unguren
September 27, 2011 at 3:07 pmThe difference between PAL and NTSC footage is framerate and framesize. And you can mix different sizes and rates in a Premiere sequence. (Granted, it may not always give you the best results.) If you want to export as PAL, then be sure to set up your sequence with PAl settings.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Vince Becquiot
September 27, 2011 at 5:18 pmBen,
Indeed you can mix, but the result, to my eyes at least, will be pretty bad in most cases, the more motion, the worst it gets. Your best options are Twixtor or a plugin from Video Copilot (free but very render intensive).
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area
