Activity Forums Adobe Premiere Pro NTSC and PAL in the same NTSC project
  • NTSC and PAL in the same NTSC project
    Posted by Ryan Santos on January 31, 2008 at 6:26 am
    I’m outputting my projects as NTSC. My footages are both NTSC and PAL. Should I just open an NTSC project and dump both NTSC and PAL footages to the timeline? Or should I convert the PAL footages to NTSC first using After Effects? (If so, how is it done in AE?) Thanks.
    Vince Becquiot replied 18 years, 7 months ago 3 Members · 4 Replies
  • Vince Becquiot
    January 31, 2008 at 6:51 am
    You’ll need to convert the footage first.
    Vince
  • Ryan Santos
    January 31, 2008 at 12:20 pm
    How? Can I start with a PAL project then export to NTSC? Or should I do it in After Effects?
  • Darren Edwards
    January 31, 2008 at 3:47 pm
    After Effects has quite advanced pull-up and pull-down
    abilities – and Magic Bullet Frames (AE plugin) is even
    better. You need to be in the ‘After Effects Basics’
    forum, or you could try – call me crazy – but you
    could try opening After Effects’ help index and doing
    a search for NTSC/PAL conversion.
    D.
    x-gf.com
  • Vince Becquiot
    February 1, 2008 at 8:41 pm
    I was using Procoder for a long time to convert to PAL, then I found that the newest version (3.0) was giving pretty poor results (at least for that task). Turns out, the old Canopus team left after Grass Valley moved in… The bad part id that the previous version didn’t work on 64 bit OS. My new best friend is Tmpgenc Express. Beats every conversion quality I’ve seen so far, it’s really fast and best of all, it’s quite inexpensive.
    Vince
