Activity Forums Apple Final Cut Pro Legacy NTSC and PAL in same sequence
  • NTSC and PAL in same sequence
    Posted by Rap on November 15, 2006 at 9:34 pm
    Hey guys, I am working on an NTSC project and I have PAL footage that I need to edit in my movie, I thought that I need to convert my PAL footage to NTSC but editing the PAL to an NTSC sequence the PAL footage looks great and doesn
    Broken replied 19 years, 9 months ago 2 Members · 2 Replies
  • Rap
    November 15, 2006 at 9:53 pm
    ok i guess i got the answer, i ran the video through my DV player and i got a stroby video and i tried then with the nattress conversion, it looks fine but not perfect. is this the best option ? (nattress?)
    thanks
  • Broken
    November 17, 2006 at 5:27 pm
    It is not the best answer. As you have learned, you can’t mix footage from thwo different systems in the same FCP timeline. You need to choose the system in which you’re going to edit: NTSC or PAL. You then have to convert the non-standard footage to that system BEFORE you edit. Nattress does a good job of that.
    Doing skipping the standards conversion step before you edit will make your life a LOT harder as you come to the end of the project. It might even force you start over from square 1.
    Dave LaRonde
    Sr. Promotion Producer
    KCRG-TV
