Activity Forums Adobe After Effects NTSC : 30 fps to 29.97 fps
  • NTSC : 30 fps to 29.97 fps
    Posted by Tylerdurden on March 9, 2007 at 11:09 pm
    Aloha,
    Don’t know if this has been discussed already, but I can’t find it on the forum.
    I work with cinema 4D on an animation that will be show on TV (NTSC).
    I render out of C4D at 30fps (I can’t render out of c4d at 29.97fps) then in after effects do I:
    – just drop the 30 fps tga sequence imported into a 29.97 fps composition and render the new movie out?
    – or select the 30 fps tga sequence imported , “interpret footage” and change to “conform to framerate 29.97 frames per second” and drop the sequence into a 29.97 fps composition?
    – or work in after effects also in a 30fps composition and just select 29.97fps in ther after effects render settings when I export the final movie?
    Thanks!!!
    Marc Estrada replied 14 years, 10 months ago 3 Members · 2 Replies
  • Robert Houghton
    March 10, 2007 at 12:09 am
    I would use option #1 unless you were trying to match the 3D to a video, then possibly #2. If you do #3 it could throw audio out of synch but that’s if your project is long enough to account for the .97 frames 😉
    -Rob
    Motion Graphics Animation
    Professional & Freelance
    Respond2
    Opinions expressed above are not in any way connected to Respond2.
    Personal website under construction 😉
  • Marc Estrada
    November 6, 2011 at 1:45 am
    Hi, I have a similar question about the Frames Per Second for Broadcasting NTSC Animations, What is the best way to make an Animation for NTSC Broadcasting, is it 29.97 fps or 30 fps?
    I know for Film it’s 24 fps, thanks
