Activity Forums Blackmagic Design NTSC 10-bit Easy Setup Broken + other things in 6.2
  • NTSC 10-bit Easy Setup Broken + other things in 6.2
    Posted by Chris Borjis on June 1, 2007 at 10:23 pm
    (multibridge extreme on a G5 quad mac)
    Why did you guys set the NTSC 10-bit easy setup with 44khz audio?
    The audio doesn’t even capture when properly set to 48khz.
    When will that be fixed?
    Why does the NTSC 10-bit capture the video as 634×480
    instead of full 720×486?
    At this moment I have to use the Pro-res easy setup just to get work done.
    Also, you have not yet fixed the jittery video on a panasonic 9uk plasma via hdmi….kristian acknowledged that one.
    6.2 does not fix the shifted looking image over hdmi either.
    I’ll be honest with you, I’m really getting fed up with your hardware not delivering what its promised and I’ll probably be selling this multibridge extreme asap to swap out with a Kona 3. Nice job fellas.
    Chris Borjis replied 19 years, 3 months ago 2 Members · 3 Replies
  • Chris Borjis
    June 1, 2007 at 11:00 pm
    It appears the 8-bit NTSC SD uncompressed is messed up too.
    not full resolution and no audio though quicktime says there is.
  • Kristian Lam
    June 5, 2007 at 12:10 pm
    [Borjis] “Why does the NTSC 10-bit capture the video as 634×480
    instead of full 720×486?”
    This is a Quicktime “feature” which you read about here:
    https://docs.info.apple.com/article.html?artnum=303928
    I’ll also email you seperately about the HDMI output to your display as I have a new tool to extract some information we need from the display.
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Borjis
    June 5, 2007 at 6:35 pm
    ok sounds good.
    do you have some new easy setups in the works too to fix the audio not capturing on NTSC uncompressed easy setups?
