Activity Forums Blackmagic Design NTSC 10 bit digitizing problem
  • NTSC 10 bit digitizing problem
    Posted by Roger Lansing on May 1, 2007 at 12:08 pm
    We recently updated Quicktime, Final Cut Pro and our Mac OS and now Blackmagic no longer recognizes a video signal when trying to digitize using the NTSC 10 bit setting. It worked like a champ prior to the upgrade. Please help! We are banging our heads against deadlines and I am frustrated with trying to figure this out.
    Roger Lansing replied 19 years, 4 months ago 3 Members · 4 Replies
  • Kristian Lam
    May 1, 2007 at 12:12 pm
    Hi Roger,
    Are you getting the No Video Input message? What about 8-bit NTSC?
    Could you double check by trying to capture with the Blackmagic Deck Control application and see if you’re able to capture?
    regards
    Kristian Lam
    Blackmagic Design
  • Roger Lansing
    May 1, 2007 at 1:39 pm
    Kristian,
    Yes I am getting the “No Video Input” message. I have tried with the Deck Control app and am getting the same thing.
    Here are my particulars:
    Dual 2.3 GHz Power PC G5
    6.5 GB DDR2 SDRAM
    OSX 10.4.8
    Final Cut Pro 5.1
    Blackmagic 5.2
    Quicktime 7.1.3
    We recently added an Apple XServe Raid to our system, and in the process upgraded our OS, FCP, QT and Blackmagic. Don’t know if that will help you at all.
    Thanks.
    Roger
  • Luke Maslen
    May 2, 2007 at 6:25 am
    Hi Roger,
    It would be a good idea to install the latest DeckLink 6.1 drivers, partly to ensure compatibility with Final Cut Pro 5.1.4 and partly in case the system upgrade has left behind some critical components of the drivers. Please install the latest drivers and then let us know how it goes.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Roger Lansing
    May 3, 2007 at 1:23 pm
    We did install the 6.1 driver and still the problems exist. I am coming to the conclusion that we either have a software conflict (or conflicts) or a very serious hardware issue with the Blackmagic. I am hoping its software, because ultimately that can be fixed by doing a clean install of the OS and all of our other software. That may be my next step. Can you please give me a correct software configuration for Blackmagic, Quicktime, and Final Cut Pro Studio using Mac OSX 10.4.8 on a Dual 2.3 GHz Power PC G5 with 6.5 GB DDR2 SDRAM.
    Thanks in advance.
    Roger C. Lansing
    Multi-Media Production Coordinator
    National Baseball Hall of Fame
    Cooperstown, NY
