Activity Forums Broadcasting NSCaster recommend streaming setting to Hitbox.tv
  • NSCaster recommend streaming setting to Hitbox.tv
    Posted by Eric Deng on September 2, 2016 at 6:43 am
    NSCaster is HD streaming software. NSCaster streaming setting can modify as user like. NSCaster have only some default settings because its HD and support up to 108060p
    These setting for 720HD
    NSCaster recommends settings to Hitbox.tv send a single stream at 720p resolution using the following settings:
    Quality Resolution Video Bitrate Audio Bitrate Frames Per Second Video Codec h.264 Profile Keyframe interval Audio Codec Audio Channels
    HD 720 1280×720 1000 – 2000 kbps 48-128kbps 30 h.264 Main 2 Seconds AAC Mono or Stereo
    It’s for continues streaming to hitbox.tv HD quality.
    These settings for 1080p
    NSCaster recommends settings to Hitbox.tv send a single stream at 1080p resolution using the following settings:
    HD 1080 1920×1080 4,000-8,000 kbps 128kbps 30* h.264 Main or High 2 Seconds AAC Stereo
    For successful live streaming, you need a high quality internet connection. A connection that is sufficient to check email or load web pages may not be good enough for streaming. You don’t need “an” internet connection, you need a high quality internet connection, particularly to do uninterrupted HD streaming.
    Not all connections are of the same quality. You want to use a wired ethernet connection and not use WiFi as WiFi connections are more prone to fluctuation in quality and can more easily drop.
    If you are not on a coporate network, you can check with your internet service provider to purchase a plan that has the appropriate level of service for streaming.
    Eric Deng replied 10 years ago 1 Member · 0 Replies
  • 0 Replies
