Activity Forums Maxon Cinema 4D novice question: creating ribbon with material
  • novice question: creating ribbon with material
    Posted by Vikas Sodhani on April 27, 2005 at 4:35 am
    Hi I am new to Cinema 4d and would like to do the following:
    I want to add a moving ribbon to my video. I have path deformer (https://www.tarabella.it/c4d/pathdeformer/) which will deform my ribbon on a path.
    My problem is in creating a ribbon that i am envisioning. I have created a ribbon like object from a spline but now I would like to add a material to it. when i drag a material under the spline in the object window it only appears to change the spline outline. What i would like to see is it fill the spline.
    Also is there a good place to learn how to paint on my new shape (the ribbon). Would the best be via body paint?
    Thanks so much.
    -vikas-
    Vikas Sodhani replied 21 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    April 27, 2005 at 11:12 pm
    ‘ribbon like object’? Can you post it? Other than that it should be a poly object
  • Vikas Sodhani
    April 29, 2005 at 1:35 am
    sorry i actually figured a piece of this out. i needed to add a NURBs to the closed spline before i could add a material to it.
    the question i have now is is there an easy way to add an outline to my new object. what ive done is create a flat closed spline then added the extrude nurb to it. From there ive added a material and made this new object move around a background that is a video clip. The problem is that the animated object needs an outline because it looks formless without it. In adobe illustrator this would be analgous to adding a stroke. I am new to cinema 4d and dont know if there is something similar.
    Thanks so much.
    -vikas-
