Activity › Forums › Adobe Premiere Pro › Novice Question About Audio
Posted by Bok Toh on September 9, 2011 at 2:27 pmHello all:
I am trying to insert an audio track but it’s letting me insert onto “Audio 5” only. Does anyone know why?
Here are my settings:
Editing mode: P2 1080i/1080p 60Hz DVCPROHD
Video: 1280 x 1080 (1.5)
29.97 fps
48000 Hz – StereoThanks!
Toh
Bok Toh replied 15 years ago 4 Members · 4 Replies -
Ben G unguren
September 9, 2011 at 3:38 pmIn Premiere, each audio track is of a certain sort — mono, dual mono, dual stereo, surround sound, etc. The type of audio that you’re putting on the track needs to match with the type of audio that the particular track expects. My guess is that you are putting a mono track into the timeline, and audio tracks 1-4 are all stereo, or vice versa….
You can modify how Premiere interprets the audio for a particular clip by right clicking it in the project window and choosing Modify–>Audio…. (or something like that). Note that as soon as a clip has been inserted into a timeline, you CANNOT change the audio type. You need to import the audio as a new clip, then interpret, then edit.
If you’re coming from FCP, this will feel a bit unusual for a while….
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Todd Kopriva
September 12, 2011 at 2:27 amSee this video for more information about the answer that Ben gave you:
https://www.video2brain.com/en/videos-4009.htm———————————————————————————————————
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Jeff Pulera
September 12, 2011 at 5:47 pmYou can delete the empty audio tracks so that the NEW track is not pushed way down to the bottom. Right click on the left where it says “Audio 1” and choose “delete unused”
Jeff Pulera
Safe Harbor Computers -
Bok Toh
September 13, 2011 at 2:10 pmThanks to all who replied. It was a mono track and I was able to change its setting to make it work. 🙂
