novation extra control panel
I’ve been running this for a while pretty successfully, so I figured its about time I shared this.
https://www.contact-di.com/files/resolve/novation.jpg
I’ve created macro’s/shortcuts for the 64 most frequent things I need in Resolve.
Here are the label and config files for it as well. (It requires ownership of Launchpad Pro, and QuickKeys 4)
https://www.contact-di.com/files/resolve/novation.zip
Modify it as you see fit.And here’s the product..
https://www.bhphotovideo.com/c/product/654672-REG/Novation_LAUNCHPAD_Launchpad_Ableton_Live.htmlNotes:
- Labels print on 3/4″ avery clear return.
- Shortcuts in general in Resolve can be window specific. Some things require your mouse to be in focus of the node/window/timeline region to work. Obviously that issue affects this panel as well.
- “Display Node graph” requires the mouse to be over the still you want to display.
- “Combine shapes” isn’t working yet. I’ll update later, but please post if you get to it first.
Good luck!
