Activity Forums VEGAS Pro Nothing will render out
  • George Dean
    September 5, 2017 at 12:01 am
    Hi Johnny, it sounds like you are doing a ‘loop region’ render, is that correct?
    I am using Windows 7 and cannot help with your OS, as I have no experience with it. You might want to fall back a couple of driver versions (or at least one) of your Nvidia card. When I was using an older Nvidia card the updates started to cause issues, so I went back to the previous version I stopped updating them. Although this just doesn’t sound like a GPU issue to me.
    Maybe you are at the point of needing the make a clean uninstall and then clean install of your v13. Hopefully someone else here will have a suggestion.
  • Lex Ger
    September 7, 2017 at 3:43 pm
    did you try to delete the .sfk files?
    or render to another hard drive..
Page 2 of 2
