Activity Forums Adobe After Effects Nothing shows up in composition window
  • Nothing shows up in composition window
    Posted by Ray Stark on April 22, 2010 at 11:33 pm
    For some reason I can’t drag footage and/or an Effects Preset (background) into the composition window. When I do this, only a black screen appears (although the clip appears in the Project window and the Timeline). When I play the timeline, the Comp Window just shows black (however the wireframe “X” appears as though there is a clip). I checked the Mute button (“eye”). Are there any other “mute” functions that might be preventing the clip from being seen in the Comp Window? Or some command that I accidentally engaged?
    I’ve done this before with no problems. Not sure what I’m missing.
    Thanks for your help.
    Bob Root replied 16 years, 5 months ago 2 Members · 1 Reply
  • Bob Root
    April 23, 2010 at 11:43 am
    Hi Ray,
    Could be that you’ve accidentally set your FAST PREVIEW (at the bottom of your comp window) to wireframe.
    Hope this helps.
    Bob
