Activity Forums Maxon Cinema 4D nothing scales in animation?
  • nothing scales in animation?
    Posted by Eugene Hooper on May 27, 2009 at 12:39 am
    This is strange, I know it must be something simple but I’m doing some basic animating. I use the autokeyframe and manual key frame and I can manage to move or rotate things fine, but nothing seems to scale in animation? I’m puzzled, I use the same method as I do for rotate/move but scale doesnt seem to want to work. The object I am using (trying to anyway) is within a null object and consists of several objects.
    Any ideas? Cheers in advance.
    Eugene
    Adam Trachtenberg replied 17 years, 3 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    May 27, 2009 at 12:30 am
    You have to switch to the object tool in order to animate scale … or you can animate the scale parameter the object’s coordinates tab (attributes manager).
  • Eugene Hooper
    May 27, 2009 at 1:03 am
    thanks! although I don’t understand why you have to switch to this mode for scaling? Why is this so?
  • Adam Trachtenberg
    May 27, 2009 at 4:57 am
    Basically, the model tool scales the actual geometry, but the object tool scales the object axis. Cinema only recognizes the scaling of the axis for animation (unless you are recording point-level animation). I realize that’s not a very satisfactory answer, but it’s the best I can do. 🙂
