Activity Forums VEGAS Pro Not Track-Level, Clip/Event-Level Volume Envelopes & Composite-Level Envelopes?
  • Not Track-Level, Clip/Event-Level Volume Envelopes & Composite-Level Envelopes?
    Posted by Jill Simpson on April 7, 2009 at 12:15 am
    Vegas lets us insert clip/event envelopes for Velocity and for Transition Progress, but Volume Envelopes and Composite-Level Envelopes are applied to the whole track.
    Why?
    Is it possible to apply these envelopes to just one clip?
    If I have an audio clip on track 5 that I want to reduce to background audio while the audio on track 3 stays normal, what’s the easiest way to do this? (I don’t want to slide track 5’s volume fader down, because I want other clips on track 5 to be at normal volume.)
    Mike Kujbida replied 17 years, 5 months ago 2 Members · 3 Replies
  • Mike Kujbida
    April 7, 2009 at 1:00 am
    You do realize that all you need to do with Volume envelopes is add 2 points before and 2 points after the clip and drag the centre of it down.
    It takes less time to do than it did to type this.
    Here’s a different way of doing it that you might like.
    Bring your cursor up to the top of the audio clip on track 5.
    You’ll see it turn into a double arrow (up/down) with the words Gain is 0 db.
    Drag it down to the appropriate level.
  • Jill Simpson
    April 7, 2009 at 2:18 am
    I know adding 4 points (and dragging 2) is not a terrible thing, but that takes 10 clicks, not counting the initial adding of the envelope.
    I never noticed the “gain is 0 db” arrow method before. Thanks.
    The same method works for composite levels: hovering at the top of any video track brings up an “opacity is 100%” [thing] which can be click-dragged down.
    Solved x 2, except:
    When we do want a volume/composite-level envelope, we should be able to add it to an event, because otherwise:
    (a) !!! throughout the track (perhaps 90 minutes or so) there is one more thing that [pops up] when hovered over, i.e. gets in our way!!!
    (b) when rendering, I wonder if portions of video that would require [no processing], would now require time-consuming processing.
  • Mike Kujbida
    April 7, 2009 at 2:35 am
    “I know adding 4 points (and dragging 2) is not a terrible thing, but that takes 10 clicks, not counting the initial adding of the envelope.”
    If you’re using a pro version of Vegas that supports scripting, try Edward Troxel’s FourPoints script as discussed in this thread here on the Cow.
    For your envelope “wants”, send your suggestions to Sony – and then wait and wait and … 🙁
    Vegas 8 Pro has “smart rendering” so any event that hasn’t been altered in any way shape or form flies through the render process.
