Activity Forums VEGAS Pro Not sure what is going on here
  • Not sure what is going on here
    Posted by Wayne Jenkins on July 1, 2011 at 2:55 am
    I’m working on a new project and recently I’ve come across something that I can’t figure out.
    When I try to insert a small image over the top of my video or even text, it seems to get cut off both to the right side if I go far enough and to the left. Also in the upper and lower areas.
    What am I missing here as far as setting up my video? Any help would greatly be appreciated.
    Thank you all so much for this site. I continue to learn a lot as I read other posts!
    Wayne Jenkins
    John Rofrano replied 15 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • Mike Kujbida
    July 1, 2011 at 4:06 am
    Open the Pan/Crop window on the image, right-click in the middle of it and choose “Match Output Aspect”.
  • Wayne Jenkins
    July 1, 2011 at 4:18 am
    Yeah, I’ve done that before and it’s work, but for some reason, on this project, that option doesn’t do anything. It’s sure bugging me. Not sure if I accidentally set something wrong or what.
  • Mike Kujbida
    July 1, 2011 at 4:32 am
    Do your text properties match your project properties?
  • Wayne Jenkins
    July 1, 2011 at 4:39 am
    To be honest, I really don’t know. I’ve tried going to pan & crop and changed things in the preset to see if that would make a difference, but it doesn’t. Is there someplace else to set this up?
    Thank you!
  • Mike Kujbida
    July 1, 2011 at 12:36 pm
    I’ve tried and can’t replicate your problem.
    In taking a closer look at your screenshot, it looks like there are two push transitions on the text event and neither of them start at the beginning.
    If there’s no reason for this, delete whatever is there and start again.
  • Danny Hays
    July 1, 2011 at 7:58 pm
    It looks like your using event pan and crop and cropping off the left side of the price. If your trying to resize the text this way, set the event pan and crop to default and use track motion to resize and position the text.
  • John Rofrano
    July 2, 2011 at 4:18 pm
    I would open Pan/Crop and delete all keyframes except the first one. Then make sure that you are on the first keyframe and right-click on the frame and select Restore and then right-click on the frame again and select Match Output Aspect. This will ensure that your media is the correct aspect for your project.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Wayne Jenkins
    July 2, 2011 at 5:07 pm
    John,
    That seemed to do the trick.
    I really appreciate the patience of this board to helping others. I’ve learned so much since I started reading the posts.
    Have a wonderful weekend!
  • John Rofrano
    July 2, 2011 at 11:54 pm
    Glad that fixed it for you. Have a great weekend too.
    ~jr
