Activity Forums Maxon Cinema 4D Not showing up in After Effects
  • Not showing up in After Effects
    Posted by Joe Bodego on April 2, 2019 at 11:38 pm
    Hello friends, whenever i do lets say motext with a plain object and linear falloff to do an animation of the type. When i bring it into after effects, it does not animate. Can you help?
    Steve Bentley replied 7 years, 5 months ago 2 Members · 4 Replies
  • Steve Bentley
    April 5, 2019 at 9:28 pm
    I wonder if its a font conflict. Can you use a path instead of the font in C4D (turn the font into a path in the text attributes).
  • Joe Bodego
    April 6, 2019 at 7:32 am
    how do you outline the path in cinema 4d
  • Joe Bodego
    April 6, 2019 at 7:40 am
    I turned it into an editable object then a fractured object and still won’t show up in after effects
  • Steve Bentley
    April 6, 2019 at 3:05 pm
    First, can you upload the c4d file? (just drag it into the reply box).
    Second, are you brining the c4d file into AE as a layer? or just using an export tag and exporting through the render settings? Using the latter will only allow it’s position to show up as a solid in AE.
