Activity Forums Panasonic Cameras Not seeing clips in p2 viewer for import
  • Not seeing clips in p2 viewer for import
    Posted by Todd Mcmullen on February 8, 2008 at 3:12 pm
    On some p2 folders I am unable to view the clip in the preview window. I see the clip in the left column clip viewer but when I double click it a white window shows up in viewer.
    If I just add the clip to the cue then it will import fine. however i do not need whole clip.
    Like I said this only happens on some content folders.
    what gives?
    cheers
    Todd McMullen
    Flip Flop Films
    Austin
    http://www.toddmcmullen.com
    Andreas Birkle replied 18 years, 1 month ago 4 Members · 5 Replies
  • Barry Green
    February 8, 2008 at 11:22 pm
    Are you on a Mac? Do you mean P2 Viewer or the FCP import window?
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Todd Mcmullen
    February 9, 2008 at 12:06 am
    Sorry for not providing more info.
    Yes I am on a mac with FCP v5.1.4
    And I am using the FCP p2 import window.
    thanks Barry
    Todd McMullen
    Flip Flop Films
    Austin
  • Noah Kadner
    February 9, 2008 at 6:18 am
    You want to be on FCP 6.02 for best compatibility with P2.
    Noah
    Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the HD Survival Guide!
    https://www.callboxlive.com
  • Todd Mcmullen
    February 9, 2008 at 3:19 pm
    Noah,
    Makes sense. Still not sure why some clips will not show up in viewer while the clips will be converted in the cue.
    Todd McMullen
    Flip Flop Films
    Austin
  • Andreas Birkle
    April 6, 2008 at 5:20 pm
    Dear Todd,
    unfortunatly, i have the same problem as you described in your post in february: Clips that have been visible using FCP 5.1.4 or P2 Log on a PB 10.4.2 are not visible with MACBOOK PRO 10.5.2 using P2 Content Manager. They appear white even if the preview window is giving a proper icon. Unfortunatly the software seems to change the clips or metadata. After trying to re-open them as done before with PB, they appear white there now too.
    Too bad. Did u find a solution why they are shown white in P2 Content?
    best,
    andi
