Not saving material
Posted by Vegasarian on May 11, 2006 at 8:08 amIs there any way, when saving a project, not to save unused material from the project media?.
Terry Esslinger replied 20 years, 3 months ago 5 Members · 5 Replies -
Peter Wright
May 11, 2006 at 9:25 amUse Save as then tick the box “Copy and Trim Media with Project.
Specify a new folder for this – you can also specify “handles” to allow you still to make minor adjuctments.
Once the copied version is finished, you can save space by deleting the original media files.
Peter Wright
Perth, Western Oz
http://www.allroundvision.com.au -
Edward Troxel
May 11, 2006 at 1:42 pm -
Gary Kleiner
May 11, 2006 at 3:18 pmIf you are asking how to clear unused media from your project, then hit the little lightning bolt icon in the upper left of the Project Media tab. That way, Vegas won’t ask you where that media is if it has been moved or deleted. If you meant otherwise Edward and Peter have you covered.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Terry Esslinger
May 11, 2006 at 5:59 pmA problem with this seems to be that if you used nested veg files on the timeline that the media included in those nested veggies does not get copied. If you the remove the original material you are SOL.
