Activity Forums Boris FX Not Reversing
  • Not Reversing
    Posted by Bert Delgado on November 22, 2010 at 6:04 pm
    Hello,
    I have a title clip created with Motion 4.
    I the used the blade in Final Cut Pro to cut that clip in half.
    I added a Boris 3-D filter to shatter the image on the first half of the clip.
    I would like to add the “Reverse” option from the ChangeSpeed window in FCP so instead of the image going outwards, it comes inwards to “form the message.”
    Can not make it work.
    I have rendered it, tried several times, and nothing, the clip continues to “explode” outwards. The “Reverse” option does not seem to take hold.
    Is there any secret to be able to create this effect?
    Thanks for info.
    Bert Delgado replied 15 years, 10 months ago 2 Members · 2 Replies
  • Peter Mcauley
    November 23, 2010 at 1:19 pm
    Hi Bert,
    Exactly which BCC (Boris) filter are you using to generate the shatter effect? Have you tried to set the reverse shatter using the controls in the filter?
    Cheers,
    Peter.
  • Bert Delgado
    November 23, 2010 at 6:07 pm
    Hello,
    Thanks for your prompt reply.
    I tried your suggestions and BINGO! The action is reversed.
    Thanks for the info.
    Bert Delgado
