Activity Forums VEGAS Pro Not Responding
  • Not Responding
    Posted by Gordon Nicol on January 13, 2006 at 3:35 pm
    Recently, when I launch Vegas, it freezes and I get a “not responding” message.
    I have to launch it about four times before it will settle down and open properly. It takes quite a bit of time to get the frozen version to end and then relaunch, so this is becoming quite a nuisance.
    Any ideas what might cause this?
    Thanks.
    Tae Ung replied 16 years, 9 months ago 4 Members · 4 Replies
  • Edward Troxel
    January 13, 2006 at 3:44 pm
    Do you happen to have a “WowExec” running? Sometimes 16bit drivers (like for a scanner) can cause this. Search around for problems with “Twain”.
    Edward Troxel
    JETDV Scripts
  • Gordon Nicol
    January 13, 2006 at 3:55 pm
    Thanks for your reply Edward.
    I do have a scanner but the software program isn’t running.
  • Unzarjones
    January 16, 2006 at 4:30 am
    FWIW: I had a similar problem lately that started when I connected my camcorder to capture clips and when the Windows “what do you want to do with this program?” opened it had an option to capture with Vegas. I always use the external program from inside Vegas but this time selected the Windows option and when my project went to start it kept freezing where it had to look for a certain clip(even though I did no actual capturing at the time). After changing the capture selection back to external 3rd party or whatever it’s called, the lockups ended. UJ
  • Tae Ung
    November 9, 2009 at 7:32 am
    Recently, when you open a project file, it adds dots when the frame is slow then it freezes and you get a “not responding” message.
    You have to restart it before it will settle down and open properly.
