Activity Forums Apple Final Cut Pro Legacy “Not Rendered” Message on Export to mpeg-2
  • “Not Rendered” Message on Export to mpeg-2
    Posted by David Lewis on January 22, 2006 at 4:40 am
    For some reason I can’t export to MPEG-2 for a DVD. I get a message saying the sequence is not rendered. But as far as I can tell it is rendered. I’ve tried every which way to render it, including trashing all my render files and re-rerendering. when i load the mpeg-2 profile in quick time conversion, i can see red bars along the top of the sequence (leading me to believe it’s and audio issue somewhere) — and then i get the “not rendered” message. but when I close the dialogue box and exit the export, i see no red bars and it doesn’t matter how many times i hit command-R and Option-R (or both together) or go to the file menus to achieve same, it won’t render anymore. I’ve checked sequence settings and system settings and user prefs. Any suggestions? Please help! Thanks.
    Dave
    Oh yeah, by the way, it exports fine to several other formats, but I need DVD quality video at the moment…..
    David Lewis replied 20 years, 7 months ago 2 Members · 3 Replies
  • David Lewis
  • Bret Williams
    January 22, 2006 at 6:02 am
    Make sure all the render options are checked in all menus. Make sure you have no in and out points. Select all in timeline. Press cmd+r. Press cmd+option+r (audio mixdown).
    You shouldn’t see any red lines.
    But it should export even if it’s not rendered. It would just render it for you. Might want to check QT compatibility and that sort of thing.
  • David Lewis
    January 22, 2006 at 1:56 pm
    well that worked! thanks….
