Activity › Forums › Apple Final Cut Pro Legacy › Not recognizing DVCAM thru Firewire input//////////// Please Help
Posted by J.p. Welgus on April 5, 2005 at 1:24 amTrying to Log and Capture Sony DVCAM DSR-45, thru the firewire input. Get caption thay says Unable to initialize video deck. You may still log offline cips or use Capture Now. I don’t know what to do. Thank you in advance.
Lexerton replied 21 years, 5 months ago 3 Members · 2 Replies -
Rob Forsythe
April 5, 2005 at 1:38 amThis list contains about everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire
b. Viewing in the Canvas window on the computer screen
c. Being able to record on the external FW DV deck or camcorder..Try things in this order until you find the “cure”:
1. Make sure you have View (Menu) > External > All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
2. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
3. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
4. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
5. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
6. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
7. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
8. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
9. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
10. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
11. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
12. Re-check that your FW cable is well-connected at both ends (or try a new cable).
13. Important: Quit FCP, then Restart FCP.
14. Now again, make sure you have View > External > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.Download:
https://www.macupdate.com/info.php/id/14729 -
Lexerton
April 5, 2005 at 7:59 amIf any of the above doesn’t work it must just be that the firewire board on the dsr 45 is fried (is fcp seeing the picture but not the timecode?) I have seen two DSR 45s go in the last couple of months because of hot plugging the 45. If you want to be sure NEVER hot plug (ie plug or unplug) whilst anything is on. Bad Juju. Expensive repair to the 45 may be on the cards – you have a warranty still, right?
good luck
Lex
