Activity Forums Adobe Premiere Pro Not recognizing audio in the timeline.
  • Not recognizing audio in the timeline.
    Posted by Dylan Dugas on April 4, 2014 at 7:33 pm
    I have a very large documentary project [2.5TB of media, all of which was imported to my PP CC project]. I cut my first scene from it yesterday, finished, closed out of premiere went to sleep, just woke up and opened the project.
    First thing which it did is re-conform probably about 2-4% of the media files everytime the project is opened. Before I imported media I relocated my “Media Cache” and “Media Cache Files” folders to the harddrive I am working off of. It’s 520GB of Cache files. When the project is first opened its only about 509 and then when it re-conforms the [same] clips everytime is returns to 520.
    I can live with that, I’d prefer not to, but if everything works fine, then fine however there is a bigger problem at hand that might be related I have no idea:
    When I opned the project everything looks fine (the audio tracks show waveform, everything is where I left it etc. etc.) but there is no audio upon playback. The levels are not even bouncing they are just firmly sitting at a depressing nothing. However, there is footage that I haven’t edited yet that was originally brought into the timeline that I just pushed further down the timeline but remains untouched and when I play those parts the sound does work.
    All the footage [and audio] for this scene is from the same video clip [.MTS]. Then there are some additional microphones synced up [.WAV] and there is a song [.WAV]. None of that audio that I worked on yesterday is working.
    Things I’ve tried:
    – The bars and tones: Heard the tone, tried all the solutions, nothing worked.
    – I brought in a new clip to the timeline: It worked fine
    – I made the media offline and then relinked it: didn’t work
    – I save two copies on different drives of the PP project file at the end of the day, opened both same issue.
    – Copying the scene thats not working into a new timeline: didnt work
    – Double clicking the audio clips in the timeline to bring it into the source window. They all play in source window when double clicked from timeline except the song.
    Currently using a trial version of PP CC
    The project is running off a RAID10 system from the OWC Thunderbay [thunderbolt]
    Mid 2011 iMac running OSX 10.9.2
    8GB RAM
    2.5 GHz Intel Core i5
    While it wouldn’t be the end of the world if I had to re edit this scene. I am extremely happy with it and it took over 8 hours to cut. But more importantly I can’t have this happen more than this once.
    Dylan
    Vince Becquiot replied 12 years, 5 months ago 2 Members · 1 Reply
  • Vince Becquiot
    April 6, 2014 at 3:17 am
    This is what I would do, with Premiere closed. Delete all your media cache, including the stuff that was originally in your {user}/Library/Application Support/Adobe/Common
    Then consider cutting your project in 2 parts if at all possible. Give it a new name everyday in case something gets corrupted.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
