Activity › Forums › VEGAS Pro › Not Ready to Say Good-bye to Vegas! No Getting Close.
  • Ken Bennett
    June 8, 2013 at 7:34 pm
    I haven’t really tried that yet. I guess I could bring over the media files for the project in-works on to a single drive and edit from that data.
    Thanks for that tip Phil.
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
  • Ken Bennett
    June 8, 2013 at 8:20 pm
    My system:
    MOBO: Intel P9X79 WS w/6X PCIe 3.0
    CPU: Intel i7 3930K 6-core, 3.2GHz
    RAM: 32GB DDR3
    1 LG Blu-ray burner
    1 LG DVD/CD burner
    WIN 7 64bit
    Quadro 4000 card
    RocketRAID card
    BlackMagic DeckLink card
    5 Seagate 3TB HDDs
    2 external 9TB RAID-5 boxes
    2 22″ Dell monitors
    Logitech keyboard & mouse
    The crashes:
    1. During playback, video freezes, audio continues to lay, Vegas interface goes ghostly white and then final the Vegas has stopped work message comes up.
    2. The entire Vegas interface simply vanishes. No warning. “Poof” gone.
    3. Sometimes just during editing the interface will lockup. The everything in #1 takes place.
    I will try all those other suggestions. This is a custom built system and I have know the builder for over 20 years so replacing/fixing components is no big issue. Just a slight cost if any.
    Crashes started back in Vegas 10-11 on another system, but it was an old computer.
    I’ll let you know what I find after your suggestions.
    Thanks Stephen
    Ken Bennett
    Video Adventures
  • Ken Bennett
    June 8, 2013 at 8:22 pm
    I do have a script that will autosave every 60 seconds.
    Ken Bennett
    Video Adventures
  • Ken Bennett
    June 8, 2013 at 8:23 pm
    BTW I have a 1200w PS in this system.
    Ken Bennett
    Video Adventures
  • John Rofrano
    June 8, 2013 at 9:46 pm
    [Ken Bennett] “I haven’t really tried that yet. I guess I could bring over the media files for the project in-works on to a single drive and edit from that data.”
    I’m not sure if it matters but I only use my RAID 5 for archiving. I edit everything on internal SATA drives or Non-RAID eSATA drives and I don’t have a lot of crashes. So I agree to copy one project to an internal hard drive and see if the crashes are less just to get the RAID out of the equation.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    June 9, 2013 at 2:19 pm
    If a program freezes up and the screen goes “gray”, often followed by a message like: “Program has stopped responding”.
    OK, why has it stopped responding? The usual suspect is that a process required by the program has itself stopped or failed.
    You can use the Windows Resource Monitor to try to determine what process has caused the problem.
    Go to Start, Run, and enter resmon
    In the Overview tab, look for the program in the image column.
    Right-click on the program image name and select “Analyze Wait Chain”
    If a process is the problem, you can try to simply end the process. More often than not (in my experience) this usually fixes the immediate problem and the program can continue running. Back up your work and Google the offending process to see if there may be a fix. (It’s a long shot, though.)
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
Page 2 of 2
