Activity Forums AJA Video Systems not mirroring on desktop
  • not mirroring on desktop
    Posted by Chris Holmes on May 3, 2007 at 8:06 pm
    I’m preparing to edit a new project, and would like to work with a larger frame size than OfflineRT provides. However, when I set up my clips to be PhotoJPEG 720×486 @ 40% and play them in the Viewer or Canvas, the output isn’t mirrored on the desktop.
    Sequence settings are the same as the clips. Everything plays out on the monitor fine, but it’s simply not mirrored on the desktop.
    Is there something I’m forgetting.
    Dual 2 GHz G5
    FCP STUDIO
    AJA IO
    The only big thing is that we’re not capturing off tape, a video/audio/TC Burn tap off the camera was run to a DVD recorder, and I’m using these camera DVD’s of the interviews as the offline material. It’s alot faster to use MPEG StreamClip to batch in all the interviews, over 50 hrs, than to capture them.
    thanks
    Chris
    Chris Holmes replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
