Activity › Forums › DaVinci Resolve › Not hearing offline reference clip audio in color page
Posted by Michael Lansdell on May 31, 2016 at 10:15 amAny ideas why this might be? It’s very annoying!
If you need more info please say.
Many thanks,
Michael
Marc Wielage replied 10 years, 3 months ago 3 Members · 2 Replies -
Glenn Sakatch
May 31, 2016 at 10:35 pmI’ve always had issues with the offline reference in Resolve. Import a clip as reference, assign it to a timeline…in older versions it would play in one tab, but not the other. Haven’t tried it in 12 yet. Personally, I find it much easier to simply bring it in as regular media, and drop it on a free track on the timeline. Mute the video track when I’m done, and use the audio track as my reference playback sound. I don’t have to worry about time offsets or anything like that. Just sync up the two pictures, and I’m off and running.
If I need to check something on the video, I can simply un mute the track for a look see.
If I want to check offline vs online, I simply put a transparency on the offline, or resize it to a lower corner box.
very simple.
Glenn
Marc Wielage
June 1, 2016 at 12:08 amI generally only use the Offline Reference feature for picture, not sound. If I needed to hear the sound, then what I would do is pull out the WAV file from within the Reference image as a separate file, then bring that into the timeline and drop it into an unused track. If I needed to hear it, then I’d turn off the other tracks and just activate the Reference audio track.
