Activity › Forums › Blackmagic Design › Not hearing audio during capture via AES in Premiere Pro 1.5!
  • Not hearing audio during capture via AES in Premiere Pro 1.5!
    Posted by Michony on December 23, 2005 at 6:20 pm
    Hi there I have the followin problem, during capture in Premier Pro 1.5,
    I’m not hearing audio on my computer speakers, after the capture the audio is perfect but during the capture there is no sound HELP???
    Michony replied 20 years, 9 months ago 2 Members · 2 Replies
  • Shane Chadder
    December 25, 2005 at 3:55 am
    No one else has offered any suggestions so I will, but I’m guessing…
    1) If you Decklink card is set to feed black to your deck during capture you lose the ability to monitor video, maybe audio to?
    2) Try setting Premiere to use the computer sound card for audio playback and see if that is a work around.
    Shane
  • Michony
    December 25, 2005 at 10:00 am
    Thanx, but this is not the problem!
    I use external black burst generator and allready set premiere to
    use Audio Hardware!
