Activity Forums Adobe Premiere Pro not hearing audio, but computer sound is working, so . . .
  • not hearing audio, but computer sound is working, so . . .
    Posted by Jim Williams on May 19, 2019 at 10:42 pm
    I have a headset on, plugged in, etc. and cannot hear the videos. I recall a preferences menu, but have not been in the program recently enough to find it. Help!
    James Barry replied 7 years, 3 months ago 2 Members · 2 Replies
  • Jim Williams
    May 19, 2019 at 11:16 pm
    Fixed that, found preferences way down in the edit menu, and went from there. Now, I cannot figure out how to get the audio that is connected with the video that is loaded in, to also show, and be heard in the edit window. I edit the footage I need and move it over, but don’t know how to get the sound to make the trip. Ideas?
  • James Barry
    May 20, 2019 at 7:42 pm
    Without further details all I can give you is some random help. Here are a list of things to check in list of order to check them in.
    – Check to see what your computer’s OS audio output is. In OSX option-click the speaker icon in the top right and be sure that the correct output is selected
    – In Premiere go to Preferences>Audio Hardware and under “Default Output” select the correct output so that it matches the output of or operating system
    – If you’re still not hearing play back, but your audio is registering on the audio meter, solo one of the audio tracks and then UN-solo that track.
