Activity › Forums › Maxon Cinema 4D › Not getting multi passes from Open EXR render – Redshift AOV manager – C4D R26
  • Not getting multi passes from Open EXR render – Redshift AOV manager – C4D R26
    Posted by Bart Stevens on May 26, 2022 at 10:25 pm
    I’m getting a couple error messages, and not sure what to make of it.
    In the bottom of the Redshift RenderView is see a message:
    “AOV: Multi-Part Direct output enabled, but no Direct AOVs detected. Disabling Multi-Part output.”
    In the Redshift Feedback Display, for each pass I see this message (GI example):
    Warning AOV: Global Illumination AOV ‘GI’ is not available during Deep output. Skipping
    I’m not sure what “Deep output” is, but guessing that part of the problem.
    All feedback is greatly appreciated.
    Boston Cainfra replied 3 years, 7 months ago 3 Members · 2 Replies
  • David Lee
    February 23, 2023 at 2:08 pm
    I meet the same issues, and i don’t how it happened. I cheked Everything i’ve setten, but these not make any sense. Then I build a new rendering setting in c4d, drag all the aovs to the new one, and it solved.
  • Boston Cainfra
    March 3, 2023 at 7:52 pm
    Hello
    If the issue is only these warnings then its okay to ignore them
    Tbh this problem is solve by hit and try method and you can also build a new rendering setting in c4d,then try drag all the aovs to the new one and check if it’s solved
