Activity Forums Apple Final Cut Pro Legacy not getting firewire signal coming out, but captures fine going in
  • not getting firewire signal coming out, but captures fine going in
    Posted by Jimmy on May 2, 2005 at 8:38 am
    Hello everyone,
    I have been having problems getting a firewire signal out of FCP. I’ve been using
    firewire out > into a DV converter to RCA (Hollywood Dazzle bridge) > plugged into a
    monitor to watch my cuts. Ever since I brought in DV footage using firewire from a
    mini dv camera, I can’t get a firewire signal out into the monitor thru the bridge or straight
    into my camera. Also my firewire drive in the other slot unmounts when i plug in the camera’s
    firewire cord. Getting signal in but nothing out. Anyone have any ideas? Thanks
    G4 quicksilver
    933mhz
    1.0GB RAM
    d2 lacie big disk 500
    James
    Jimmy replied 21 years, 4 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    May 2, 2005 at 12:05 pm
    Not a fan of the Dazzle, and wonder if that isn’t part of the problem, however you cannot have both it and and camera connected at the same time, nor can you have the log and capture window open if you want to view externally. I’d start by disconnecting the Hollywood box, and using just the camera. If this fails, you might try resetting the PMU switch on your motherboard. It’s near the battery, and you must have the Mac’s power cord disconnected when you push this little button. It resets the power management on your mac (also zaps the pram), and I’ve seen this fix FW port problems, if this is the problem…
    Jerry
  • Walter Biscardi
    May 2, 2005 at 7:23 pm
    [Jerry Hofmann] “Not a fan of the Dazzle, “
    Not a big fan either. I’d look at the Canopus AVDC-100 instead. That being said, follow the rest of Jerry’s suggestions about removing the box and trying just the camera. Also his note on only having one Firewire video / audio device connected at any one time.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Jimmy
    May 2, 2005 at 8:00 pm
    I reset the PMU switch but it didn’t work. Any other ideas? My main problem is that I’m using the d2 lacie drive
    for all my footage so I have to have it plugged in. The dazzle has been working fine up till now because I have
    been digitizing only analog. It was only until I digitized the mini dv footage that things haven’t been working
    properly. Any other ideas to get a dv signal out to look at on a monitor as I work? I’m willing to upgrade.
    Thanks.
    James
  • Jerry Hofmann
    May 3, 2005 at 1:07 pm
    Having the Dazzle not connected, and using the camera only with the Log and Capture window closed, and the view set to “all frames” isn’t working then? Are you connecting the camera to it’s own FW port on the Mac? if not try that too.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jimmy
    May 4, 2005 at 5:19 pm
    Setting View to “All Frames” did the trick. Thank you. I’m still using the Dazzle.
    James
    Quicksilver G4
    933mhz
    1.0 GB Ram
    d2 lacie big disk extreme
