Activity › Forums › Apple Final Cut Pro Legacy › ! Not Found and ! Out of Memory
  • ! Not Found and ! Out of Memory
    Posted by Roddy Jamieson on May 19, 2006 at 6:08 pm
    I am running FCP 5.1 and Quicktime 7.04. I have been working on a sequence which now will not load I just get the above 2 messages in that order.
    I regularly “saved All” during the work.
    I have gone to the Autosave Vault only to find multiple folders all referring to the project, instead of just one. All of the saves back to when I started the work today come up as above.
    I’ve trashed prefs with FCP Rescue etc, re-started.,……. nothing
    Any sugestions, other than going back to Avid, greatfully received.
    Roddy Jamieson
    Roddy Jamieson replied 20 years, 4 months ago 2 Members · 2 Replies
  • David Bogie
    May 19, 2006 at 8:41 pm
    We often see this error on corrupt files and files to which you really don’t have access. This could be a total disaster for you for an easily fixed user account management situation. those files may have had their read privileges changed so check those in Get Info.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=8&postid=889598
    A search for “out of memory” turned up a bunch of hits but the threads are inconclusive, onoy you can decide if the information applies to you.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=8&postid=886041
    Avid brakes? Cool tools, got ’em on my recumbent.
    bogiesan
  • Roddy Jamieson
    May 20, 2006 at 8:36 am
    Thanks for your reply. I had checked those posts earlier. Permissions are ok. Decided to take the hit and loose about 2 hours work by opening an older vault file.
    Thanks again.
    Roddy Jamieson
