Activity › Forums › VEGAS Pro › Not enough space in the temporary file folder
  • Not enough space in the temporary file folder
    Posted by Bo Gustavsson on January 18, 2020 at 9:56 am
    Hello Vegas friends out there!
    When I try to make a BluRay disc in Architect I get a warning and the message: “There is not enough space in the temporary files folder for preparing the disc”. Where do I find there temporary files and what to do?
    Thank´s in advance.
    Bo in Sweden
    Francois Pénzes replied 6 years, 8 months ago 2 Members · 1 Reply
  • Francois Pénzes
    January 19, 2020 at 12:20 am
    Hi Bo
    First off, you may want to see were the temp files for Architect are on your computer. By default, this is how and were they are created after first install (your name should be in lieu of mine of course)
    This is how you get there: Options/Preferences/Burning
    Don’t ask me the technical reason why but Architect needs at least twice the amount of space needed when the temp files are created. So, with that in mind, you can change were you want your temp files (both of them) preferably on a separate drive.
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
