Activity › Forums › Adobe Photoshop › Not enough RAM when opening files in PS6
  • Not enough RAM when opening files in PS6
    Posted by Arne_hamburg on August 30, 2006 at 10:17 am
    Hello,
    I create .psd-files with PS CS1 and/or CS2 and save them using the “maximize PSD file Compatibility” option. Trying to open these files on a PIII 1GHz 256MB RAM PC running PS6 results in a “not enough ram”-message. The filesize does not matter though, even 30kB-PSD-files will not open at all. Any files created on the PC with PS6 will open nicely, even with filesizes exceeding 70MB. Trying to enlarge the maximum memory usage for PS6 does not help (currently set to 70%). The workvolume of PS6 is not the same drive as the windows-volume and has plenty of GBytes free space.
    Any suggestions to open the PSDs in PS6 besides updating the software?
    Thanks, Arne
    Arne_hamburg replied 20 years ago 2 Members · 2 Replies
  • Richard Harrington
    August 31, 2006 at 4:55 am
    You can split the layer files apart using teh Script Export Layers as Files then reassemble
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
  • Arne_hamburg
    September 4, 2006 at 11:23 am
    Hi Richard,
    your tip worked, but with several files containing more than 50 layers your method is not really acceptable. I have found another way to open the files: Opening them in ImageReady (on the PS6-system) works well without the “not enough RAM” message. Saving them with ImageReady somehow alters the files readable by PS6.
    Greetings, Arne
