Activity Forums Blackmagic Design not enough pci slots
  • not enough pci slots
    Posted by James Marshall on December 12, 2005 at 11:25 am
    is there a way of getting more than 3 pci slots on a g5mac.
    Years ago avid supplied a pci extenderbox to allow all of the cards needed to run an avid.
    I have a decklink, sata card, fw card and scsi card, and I canniot have all installed at the same time.
    Does any one out there know if There are pci extenders on the market, and if so will it work with a g5 and FCP.
    yours
    james
    Georg Misch replied 20 years, 9 months ago 3 Members · 3 Replies
  • Georg Misch
    December 12, 2005 at 4:27 pm
    Hi here’s a quote from somebody’s helpful previous post:
    Greetings
    Georg
    FYI, for those who want to keep using their perfectly fine PCI-X and PCI cards, SBS makes a PCIe-to-PCIX expansion chassis. We’ve tested it and it works great.
    Jeff
    Jeff Bernstein
    Digital Desktop Consulting
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
  • Nico Sandhof
    December 12, 2005 at 9:20 pm
    “SBS makes a PCIe-to-PCIX expansion chassis”
    please more about…
  • Georg Misch
    December 13, 2005 at 12:05 pm
    https://www.sbs.com/products/774/
    PCIE-PCIX-7S
    Seven-slot PCI Express to PCI-X Expansion System
    Easy to use — no software required to run in MAC OS, Windows, and Unix systems
    PCI Express host data bus
    Integrated backplane controller card
    PCI Express x4 (10 Gb/s raw throughput in each direction) interface over cable
    PCI-X segments support all legacy speeds
    Standard height x4 PCI Express host card
    PCIE-PCIX-7S is a 7-slot PCI Express to PCI-X expansion system that provides system developers an easy-to-use migration path to high speed PCI express capability while maintaining slot capacity for PCI-X and PCI cards. The system features a standard height x4 PCI Express host card, a 7-slot 4U 19-inch rackmount chassis and 5-meter cables. The expansion system is ideal for PCI-X/PCI-based multimedia and test applications that will benefit from the higher performance of PCI Express.
