Activity › Forums › Adobe After Effects › “” Not enough memory to create image buffer “
Posted by Antony Buonomo on July 26, 2005 at 6:08 pmMac G5 Tiger/3.5 gigs RAM
Can this be right?
A
Frank Weber replied 21 years, 1 month ago 3 Members · 4 Replies -
Frank Weber
July 26, 2005 at 6:31 pmAre you using sound files in the comp? Are your preview areas quite big?
If so I’ve had the same problem for -ever and I use a PC. with 2 GIG’s of ram.=I think its a mp3 and/or wav problem. Switching to other Audio formats usually helps.
PS: Wav. has less problems than mp3’s I find.
Antony Buonomo
July 26, 2005 at 9:01 pmNo audio at all. I have multi-processor support and the memory set to 160% of 2gig.
Steve Roberts
July 26, 2005 at 9:34 pmI could be wrong, but if you do a search for “Gridiron” and “error”, you may find useful threads. Apparently, installing the Gridiron plug (but not necessarily using the plug) fixes an error, which may be the error you’re seeing.
Hope that helps,
Steve -
Frank Weber
July 27, 2005 at 10:56 amOr delete the AFX preference folder so that it creates a new one.
