Activity Forums Maxon Cinema 4D Not enough memory error
  • Adam Trachtenberg
    November 9, 2015 at 5:38 pm
    What’s your render output size? How many frames are you rendering?
  • Sam Baker
    November 9, 2015 at 6:25 pm
    Sorry it took so long to reply. My render size is 1920×1080 I am not rendering multiple frames I am rendering one frame and the one you see in the picture is what the render looks like. If it helps I am using a 32-bit system with 8 gb of ddr3 memory.
  • Adam Trachtenberg
    November 10, 2015 at 4:10 pm
    Hmm … it doesn’t look like you should be running out of memory, but I can’t really tell what’s going on without the scene file.
  • Brian Jones
    November 10, 2015 at 4:12 pm
    wouldn’t 32 bit limit him to 2 GB for C4D? (or any program IIRC)
  • Adam Trachtenberg
    November 10, 2015 at 4:13 pm
    Yes, good point.
