Activity Forums Apple Final Cut Pro Not Enough Disk Space- Multi-cam Editing FCPX
  • Not Enough Disk Space- Multi-cam Editing FCPX
    Posted by Brendan Mcnamara on October 10, 2013 at 9:02 pm
    So I trying to make a multicam clip of a wedding ceremony on Final Cut Pro X and I’ve reached a point where I can no longer add clips to the multicam. It says “Not enough disk space” even though I still have 135.74 GB still available on the external hard drive I’m working from.
    The scratch disk is not on on my internal hard drive, it’s on the external where all the footage is located as well as the project and event files.
    I’m also working with h.264 codecs. I’ve made many videos this way before that were much longer with less space on the disk, so why is this happening?
    Hans Douma replied 10 years, 7 months ago 5 Members · 4 Replies
  • David Eaks
    October 11, 2013 at 2:03 am
    In preferences, do you have “Create optimized media for multicam clips” enabled? It will create Prores files for every clip added to a multicam clip, eating up drive space.
    Assuming you do, one way to reclaim some storage space and still get good editing performance would be to delete the optimized clip versions and then generate proxy media. Then switch to proxy playback preference. Oh, and turn off optimize multicam clips.
    You might even check the transcoded media folders from old projects, there’s probably 100’s of GB of other optimized media you no longer need.
  • Elysa Chao
    May 16, 2014 at 5:44 pm
    This was driving me nuts until I found the second optimize media checkbox. Sneaky. In the editing tab of preferences, there is a checkbox for “optimize media for multicam.”
  • John Link
    October 8, 2014 at 2:04 pm
    Where are the optimized optimized multicam clips stored? I have Final Cut create optimized media for all my multicam clips but I don’t see where they are.
  • Hans Douma
    January 4, 2016 at 3:39 pm
    I ran into the “not enough disk space” problem when trying to create optimized media for multiple events containing a lot of clips. When I optimize small chunks of data, the same job (i.e. optimizing many clips) is done without the disk problem, although it is taking an amazing amount of time to complete. It looks like FCPX cannot handle large amounts of data unattended. A pity, because these are typically things you could do overnight.
