Activity Forums Adobe After Effects Not acting like a 3D layer
  • Not acting like a 3D layer
    Posted by Malcolm Desoto on August 16, 2007 at 8:04 pm
    So, my camera is moving down the face of this building.
    As the camera moves, this victorian wallpaper is supposed to grow on the face of the building.
    However, the wallpaper layer is not acting like a 3d layer. Instead of staying put, it just stays in the frame while the camera moves as if it wasn’t a 3d layer.
    layer
    The 3D layer switch is activated. Any idea what gives?
    Darby Edelen replied 19 years, 1 month ago 5 Members · 12 Replies
  • 12 Replies
  • John Dickinson
    August 16, 2007 at 8:11 pm
    Have you considered precomposing the wallpaper into a comp with the building then doing the camera move in the main comp?
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Malcolm Desoto
    August 16, 2007 at 8:12 pm
    See anything suspicious?
    layer
  • Malcolm Desoto
    August 16, 2007 at 8:13 pm
    Yeah. I could. I shouldn’t have to though right?
  • Brian Charles
    August 16, 2007 at 8:22 pm
    You have a 2D layer (Bird) separating your 3D layers. This breaks the 3D world into 2 parts. Move it to the top.
  • Malcolm Desoto
    August 16, 2007 at 8:25 pm
    oh! I thought that only apllied to adjustment layers!
    I’ll go check that out right now!
  • Malcolm Desoto
    August 16, 2007 at 8:32 pm
    I wish that were the problem.
    Even with the bird and camera layers at the top of the order, The wallpaper still will not stay put.
    On a side note:
    Does the camera’s layer order really matter? In the past I’ve had it near the bottom and it didn’t seem to affect anything.
  • Malcolm Desoto
    August 16, 2007 at 8:45 pm
    Okay, I was wrong. The wallpaper layer actually is moving. It’s just moving very slowly.
    As you can see, the mask is now at the top of the frame.
    layer
    What would cause this slow movement? It’s almost as if it’s trying to pan over the entire image before I scaled it down. I originally brought it into the comp at 3072 X 2304.
    I haven’t had any problems with large files in the past.
  • Steve Roberts
    August 16, 2007 at 8:46 pm
    Naw, camera layer order doesn’t matter.
    What do you see when you use a custom view?
  • Steve Roberts
    August 16, 2007 at 8:48 pm
    Maybe you moved it really far away to make it small, and as a result, it moves slowly.
  • Malcolm Desoto
    August 16, 2007 at 8:52 pm
    Well, if that were true, it should intersect with my building layer disappear right?
