Activity Forums Boris FX Not able to move keyframes, project is saving as 4.0.3
  • Not able to move keyframes, project is saving as 4.0.3
    Posted by Ray Brown on January 25, 2008 at 5:19 pm
    Using Boris Red 4.1.5 on Mac G5 quad core intel. FCP 6 host. Created an hd project in 4.1.5 in Red engine but when I save the project Red saves it as a 4.0.3 setting. This would not be an issue except that I am using the Vector Trace tool and it doesn’t show up in Red 4.0. Solution?
    Also, used to be able to shift-click key frames to select more than 1 and re-position them, this no longer works. Is there another modifier I don’t know about? One more thing. When I export the movie file as an Amimation with millions of colors+, the background changes to white instead of black. Is this a setting I have messed up? All of these problems are in the Red Engine not in the FCP timeline.
    Ray Brown replied 18 years, 7 months ago 2 Members · 6 Replies
  • Peter Mcauley
    January 28, 2008 at 4:08 pm
    Hello,
    Sounds to me like you have a preference file for RED that needs to be deleted. I suggest that you go to this directory:
    HD/Users/Login Name/Library/Preferences/
    And delete this file:
    Boris RED (all versions) Preferences
    Then relaunch RED and see if it is behaving as expected. Please let me know whether or not this works for you.
    Peter.
  • Ray Brown
    January 28, 2008 at 5:40 pm
    Trashed everthing. No change. Even with a new timeline.
  • Peter Mcauley
    January 28, 2008 at 6:04 pm
    Okay. Follow the link that I’ve provided herewith and download the RED 4.2 updater. Install this update and please let me know if this solves the problem.
    Cheers,
    Peter.
  • Peter Mcauley
    https://www.borisfx.com/updates/
    Cheers,
    Peter.
  • Ray Brown
    January 31, 2008 at 6:53 pm
    That’s seems to fix it. haven’t had a chance to fully test, but upon initial install I am able to shift click keyframes with success.
  • Ray Brown
    January 31, 2008 at 7:02 pm
