Activity › Forums › Compression Techniques › not able to modify a copy of the default Compressor setting for dvd
  • not able to modify a copy of the default Compressor setting for dvd
    Posted by Paul Dougherty on September 10, 2014 at 8:54 pm
    not able to modify a copy of the default Compressor setting for dvd – field dominance
    In Apple Compressor I’m not able to modify a copy of the default Compressor setting for dvd (stuck on Automatic for field dominance) to ensure that the result is Interlace. I tried the default already (the source was 23.98 progressive) but there are motion artifacts in the result, again to ensure that the result is Interlace… unless someone has an idea what else might be wrong
    Paul
    Eric Strand replied 12 years ago 2 Members · 1 Reply
  • Eric Strand
    September 11, 2014 at 8:14 pm
    Hi Paul,
    I simply don’t think you can create a 23.98 interlaced DVD; 23.98 is always progressive.
    @ericstrand11
