Activity › Forums › Adobe Audition › not able to import some mp3 into audition
Posted by Accountclosed on July 21, 2005 at 11:36 pmhello all. i downloaded a sample mp3 from sounddogs and tried to import it into audition with the hopes of tweaking it, however audition isn’t accepting it as a valid mp3. any suggestions on how to make this work? thanks!
J. D. mack replied 21 years, 1 month ago 3 Members · 4 Replies -
Willie Toth
July 22, 2005 at 12:50 amDoes your install of Audition see any MP3’s? Try and download again only save as PCM wave file … Did you try and insert it on the session side? WILLIE
Accountclosed
July 22, 2005 at 4:31 pmyes, i can see mp3 files. and i did try to convert to a pcm, but it asked me the sampling rate, which i have no idea of.
im not sure what it means to insert on the session side, (i’m a novice) what does that mean?
Willie Toth
July 22, 2005 at 5:13 pmGo to the multi track side and then click on the tab across the top that says INCERT, now scroll down to audio from there go to where your MP 3 is saved click on it and hit OK … It should incert … Once you do then you can do a SAVE AS and save it as an PCM wave file … IF Audition still doesn’t see it then it is most likely your download that has a problem …….. WILLIE
J. D. mack
July 25, 2005 at 4:19 pmI’m not sure if this info will apply to your situation or not, but this might help.
First of all, when you say you are tyring to import the mp3, how do you mean? Are you clicking on File-Open, and then selecting the mp3 file from the directory where it is located? I will presume that you are. Audition should open the file at that point. However, there are some oddly formatted mp3 files that Audition will not read. This happened to me just this past week. Here is what I did.
If you do not have the program Winamp, go ahead and get the free download (full version, not lite version) from http://www.winamp.com. See if you can play the mp3 file in Winamp. If not, then there is somethig wrong with the mp3 file. If you can, then go into the options, then preferences, and then under “plug ins”, choose “output.” Select “Nullsoft Discwriter” It should be pre-configured for 44.1K 16bit PCM. Now, when you play the mp3 file in Winamp, you won’t hear anything, but Winamp will be writing a .wav file to your hard drive from the mp3 file. This new .wav file should open in Audition with no problem.
Hope that helps!
