Activity Forums Adobe Premiere Pro Not able to cut footage/audio exactly where cursor is…?
  • Not able to cut footage/audio exactly where cursor is…?
    Posted by Kyle Sidlik on March 19, 2019 at 6:28 pm
    Hi, Thank you for taking the time to read the problem I am having.
    When I import footage or audio into my sequence and try to make a cut (CMD-K) the cut will either be forward of my cursor or not cut at all. The same thing will happen when I use the razor tool, but in some areas of the footage, it will make a cut where I want it. After some research, I can not find any forums/videos with people having the same problem that I’m having. I’ve checked my sequence settings and everything checks out (Frame rate matches footage, dimensions, etc.). I’ve also cleared my cache.
    Any ideas?
    Mac High Sierra 10.13.4
    16 GB ram
    Premiere cc 13.0.1
    James Poll replied 7 years, 5 months ago 4 Members · 6 Replies
  • Tero Ahlfors
    March 19, 2019 at 7:01 pm
    I’m not at my workstation at the moment but if I recall correctly the add edit/add edit to all tracks command works if:
    -You have clip or clips selected
    or
    -The track you’re cutting is active
  • Kyle Sidlik
    March 19, 2019 at 7:03 pm
    Hi Tero,
    Thanks for responding. Yes, all footage is selected when trying to make a cut. V1and A1 are highlighted blue as well.
  • Todd Perchert
    March 20, 2019 at 5:34 pm
    It definitely sounds like a frame rate mismatch. That’s the only time I’ve seen that.
    Best way to know is to post your file specs and your sequence specs so we can see exactly what they are and what might be happening.
    TC
  • Kyle Sidlik
    March 26, 2019 at 1:58 pm
    Hi Todd thank you for responding.
    The sequence frame rate and the footage frame rate match; 23.97.
    The other thing that is happening is if I try to make a cut the cut will appear a few frames behind the cursor or after the cursor. There is no consistency with the cuts.
    I’ve updated premiere, with no change.
    I’ve opened other project files, imported the footage and the issue remains the same.
  • Todd Perchert
    March 26, 2019 at 2:11 pm
    Something you said earlier caught my attention, you said v1 and a1 were selected blue. Is this problem happening between video and audio? Or does it happen between 2 video tracks with matching frame rate? Is your audio recorded in camera at 48k?
  • James Poll
    March 26, 2019 at 5:39 pm
    Just a thought…
    You don’t have “Show Audio Time Units” selected by any chance (under the sequence’s hamburger menu)? If that’s turned on, you can scrub and zoom down to the audio sample level, but video cuts and splices will only happen on frame boundaries, which may be either ahead of or behind where your scrubber is.
    Good luck!
