Activity Forums Blackmagic Design Not able to capture SDI 1080p 59.94 signal…
  • Not able to capture SDI 1080p 59.94 signal…
    Posted by Michael Spencer on August 26, 2010 at 8:39 pm
    Are there any known issues when trying to capture an SDI 3GA Single Link 1920x1080p 59.94 signal when using the Media Express 2.1.1 and DeckLink 7.7.3?
    Joshua Helling replied 16 years ago 2 Members · 1 Reply
  • Joshua Helling
    September 1, 2010 at 8:11 pm
    The quick answer is, yes. But it is a choice not really an issue. We capture SMPTE 425m level B which would be 3GB. So 3GA format would not be supported.
    If your source has the option to choose which formate level you want you will want to set that to Level B.
    I hope that helps.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
