Activity › Forums › Apple Final Cut Pro › Not a solution
  • Not a solution
    Posted by Rich Rubasch on August 15, 2013 at 4:32 pm
    We received some Sony XDCAM 720 35mbps footage in BPAV folders. Imported into FCPX 10.0.9 and only get a green screen on the clips.
    We wanted a quick way to read the native files and make quick Windows Media encodes with a timecode window…..then kick out MP3s for transcription.
    Back to FCP 7.
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    https://www.tiltmedia.com
    Ronny Courtens replied 13 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • Mark Smith
    August 15, 2013 at 4:45 pm
    I’ve seen this before with other file based footage other than sony. Are you sure you have all proper sony plug ins loaded? THat has been the root cause for m green clip experience in the past, not having the necessary plug in loaded, that is.
  • Jason Brown
    August 15, 2013 at 5:20 pm
    Have u posted in the Xdcam forum? Ian monitors that forum and responds very quickly.
  • Tim Jones
    August 15, 2013 at 5:48 pm
    I also saw this when I didn’t have the Sony CODEC module / plugin loaded.
    Here’s Apple’s note on this: XDCAAM Support for FCP X.
    Here’s the link to the plugin: XAVC/XDCAM Plug-in for Apple (PDZK-LT2)
    HTH
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Jeremy Garchow
    August 15, 2013 at 6:00 pm
    When you do get the footage working, there is no tc reader filter in FCPX.
    Someone made a custom one a long time ago, but then it broke.
    You can use a Compressor setting with the tc filter on, but you have to do each clip, one by one, from FCPX.
    The only solution is to take the files from the import and put those in compressor and add the tc reader function.
    Jeremy
  • Rich Rubasch
    August 15, 2013 at 8:58 pm
    Figured as much on both counts…need the plug in for XDCAM in FCPX and there is no timecode reader option (BTW, a professional option) so it is a non-starter.
    Rich Rubasch
    Tilt Media Inc.
  • Jeremy Garchow
    August 15, 2013 at 9:52 pm
    A plugin to read footage isn’t so bad. You needed some for FCP7 too, but a TC Reader is a basic human need at this point.
    Jeremy
  • Ronny Courtens
    August 15, 2013 at 10:54 pm
    Agreed.
    If you have only a few long clips to export for transcripts you can use Open in Timeline and drop the Timecode generator or the TimeCode Effect on the clips in their timeline. This will give you the correct burnt-in source time code and you can export to any format straight from this timeline.
    But if you have a load of short clips to export this method takes too much time. We absolutely need a time code reader that reads source tc from the clips on our main timeline.
    – Ronny
