Activity Forums Adobe After Effects Expressions Normalize Vector Issue
  • Normalize Vector Issue
    Posted by Jamie Bradshaw on September 12, 2010 at 9:29 am
    Hi all.
    I have the following expression code on a Text Layer’s Source Text (for debugging purposes).
    It’s working fine except that I’m only getting different random values for each array (pArray1) when I normalize the vector (normalise = true)
    In other words, if I set the variable normalise to false then each of the pArray1 amounts come out the same.
    Any idea why?
    Jamie
    seedRandom(index, true);
    parentType1 = [0, 0, 0];
    parentAmount1 = 4;
    minMax1 = [-1, 1];
    normalise1 = true;
    pArray1 = generateParents(parentType1, parentAmount1, minMax1, normalise1);
    str1 = "";
    for (n1 = 0; n1 < parentAmount1; n1++) {
    str1 += "Parent " + n1 + "\r";
    for (n2 = 0; n2 < parentType1.length; n2++) {
    str1 +=
    "\t" + "[" + n2 + "]: " + pArray1[n1][n2] + "\t" + "\r";
    str1 += "\t" + "length: " + length(pArray1[n1]) + "\r" +
    "\r";
    function generateParents(pType_1, pAmount_1, minMax_1, norm_1) {
    var pArray_1 = new Array();
    var pType_2 = new Array();
    for (n_2 = 0; n_2 < pAmount_1; n_2++) {
    for (n_1 = 0; n_1 < pType_1.length; n_1++) {
    pType_2[n_1] = random(minMax_1[0], minMax_1[1]);
    if (norm_1) {
    pType_3 = normalize(pType_2);
    } else {
    pType_3 = pType_2;
    pArray_1[n_2] = pType_3;
    return(pArray_1);
    JimJam•Graphics
    https://www.jimjamgraphics.com/
    Jamie Bradshaw replied 15 years, 11 months ago 1 Member · 1 Reply
  • Jamie Bradshaw
    September 13, 2010 at 9:27 am
    Aha! Caught it!
    For anyone who might be vaguely interested it was because I needed to declare the var pArray_2 = new Array(); inside the first for loop. I’m guessing so that it could clear the previous info stored in the array which it wasn’t doing if I didn’t normalize the vector.
    Here is the working code with added comments to maybe make it clearer.
    seedRandom(index , true);
    // The variables
    parentType1 = [0, 0, 0]; //define the parent type, in this case a 3d vector
    parentAmount1 = 4; //define how many original parents
    minMax1 = [-1, 1]; //define the min and max range of random values
    normalise1 = true; //normalise the vector or not
    generations1 = 20; //how many generations or iterations to calculate
    // generate the debug text so I can assess what's happening
    str1 = "";
    str1 +=
    "\r";
    // ***FUNCTIONS***
    // this function returns an array of original parents
    var pType_3 = new Array();
    if (norm_1 == false) {
    pType_3 = pType_2;
    } else {
    return(pArray_1);
    JimJam•Graphics
