Activity › Forums › VEGAS Pro › Normal Rate Problem
  • Normal Rate Problem
    Posted by Greg Longmore on August 12, 2011 at 3:23 am
    I haven’t yet had this problem but today when I imported my video and pressed play it played faster than normal. Now, I went into properties for the clip and everything is set to 1.000. The problem is with the slider in the bottom left corner it says “Rate 1.000” but the little orange triangle is just right of that, and every time I try and bring the triangle back underneath the regular slider to the 1.000 position it goes back to the right and it plays faster. If I move the triangle right from there, it stays and plays even faster. This is not what I want….help!!!
    I’ve recorded in 1080x720p @24 fps I truly hope that’s not the problem because that’s how I would like to shoot this and most of my films
    Greg Longmore replied 15 years, 1 month ago 1 Member · 1 Reply
  • Greg Longmore
    August 18, 2011 at 7:20 pm
    BUMP
