Activity › Forums › Maxon Cinema 4D › Normal displacement question.
  • Normal displacement question.
    Posted by Christian Balistrari on January 5, 2020 at 9:52 pm
    Recently started working on a new machine (Mac to PC) + migrated all of my assets & workflow between the two.
    I’ve noticed the normal displacement on a particular model is fragmented/problematic even though all settings are identical between machines.
    Correct Displacement
    Faulty Displacement
    Any help on resolving I’d be most grateful.
    arthrmusic.com
    Music | Animation | Live
    Christian Balistrari replied 6 years, 8 months ago 2 Members · 2 Replies
  • Brian Jones
    January 6, 2020 at 4:44 pm
    haven’t seen anything like that, what happens if you copy/paste it into a new project file? otherwise can you post the file (or a stripped down version with the problem part)
  • Christian Balistrari
    January 7, 2020 at 11:21 pm
    After much messing about, managed to solve by resetting the normal tab to default settings in the material settings ☺
    Thanks again.
    arthrmusic.com
